How to Cut splines with boolean
Hi all,
Im using lightburn for more Than a year now.
Very good Software! Never want to Miss it or Change anything.
Now i have a First Situation where i need some assitance.
I want to cut one ore more open vector spline with a square Objekt.
The boolean Cut does Not Work.
Please See attached Screenshot.
Has anybody a solution?
Thanks all!
Cheers
Stephan
You’ll need to use node edit for this. Both shapes need to be closed for weld/boolean to work.
I will use “Cut Shapes” for that. Pay attention to the order of selection. NB. I duplicate the frame because otherwise it will be lost during the process.
That works too. I always forget about it. :rofl:
Perfect! That worked!
Thanks a lot!
Stephan
