hello
i want to make a shape with circle but need to cut out the lowest part of the circle
Go to Edit Nodes, point the mouse over the part of the circle between those two lines, and press ‘T’ to Trim the line:
Start with this:
Make sure the circle is an editable path first:
Then click here for node editing:
Hover over the lower part:
Press T to Trim the circle:
When you’re done, go back to Select mode (press Esc) then select both parts, and go to Edit > Auto Join Selected Shapes to connect the pieces together, or you can just drag the ends together when you’re still in Edit Nodes mode to make that happen.
awesome explanation
ty so much
got it
