How to eliminate tabs?
How to eliminate tabs? Any help would be great.
Disable tabs in the cut settings layer properties.
Thank you for your quick reply. I have imported a DXF that has tabs. I wish to remove them from it when brought into LightBurn.
Thanks in advance,
Kevin
Okay, so those are hard-coded tabs in your design?
In that case you would need to remove them manually using the various drawing tools. This would be no different than if you were creating a new design.
:+1: Thank you
Kevin
