How to enable ramp setting or feature?
I see this is still ongoing, so I am going to merge these posts together to help.
Ah, okay - so I will reduce the speed and adjust the max/min power setting to see if it gives me the desired effect. To make them, as you say, ‘a bit more proud’. Wonderful description. I am trying to cut my learning curve in half as quickly as i can, while trying not to waste material. I suppose i could try the same image on the back side (no harm in the that if running a test .
MUCH appreciated
