How to enable the cleaning function when the 3D slice is enabled in the settings, to clean between passes when creating a 3D relief on the RAYCUS 50wt (JCZFiber) laser!Version of the LightBurn 1.5.01 software (Windows 11 64bit)
When you select 3D Sliced for the Image Mode, there will be an Enable clean-up pass toggle that shows up under the Image Mode selector. Turn that on, which will add a clean-up pass layer.
