I have a deer track that is an outline line drawing, but want to fill it in so the laser burns the whole track. What is the easiest process for this? Thanks!
If the deer tracks are made of closed shapes then change the Cut Layer mode to “Fill”.
If there’s some additional nuance to your needs then please attach a screenshot or the .lbrn file to review with some more detail about the complication.
Use the OFFSET command to make a slightly smaller copy of the outline, and set the results to fill. Also use FLOOD FILL under the advanced tab to save time on larger prints using offset.
