Silly question… and I did search but wasn’t sure what terms and found no results…
How do I get the camera window to go back in the sidebar as opposed to being its own window? I have X’d and tried everything I can think of. Photo attached.
Try clicking and dragging the Camera window over the docked Cuts/Layers window. When the Cuts/Layers turns gray, release the click. That will dock the Camera window there.
You can also go to ‘Window’ > ‘Reset to Default Layout’, but this will also undo any layout changes you’ve made that you may want to keep.
I had a similar problem a couple weeks ago. I could NOT get it to dock no matter what. I eventually restarted Lightroom with the shift key held down and I think that fixed it.
i had this issue too yesterday, solved minimizing LB window, not iconizing to the bar, then acting like @JTR told, once done i maximize LB again
