I have the xtool p2, I’ve figured out how to run the material tests and when I’m running the interval test, I get these lines at the end of the engraving, (hopefully my picture uploads) I tried adjusting the focal length with no luck. any suggestions would be appreciated.
You need to check these parameters
thanks for your quick reply, where can I find these settings? I tried searching for where these settings are located and came up with factory default settings
thanks again
If you create your device by importing a .lbdev usually it has the scan offset defined.
https://storage-us.xtool.com/resource/xtool/support-attachment/xTool-P2_v10.lbdev
my machine isn’t a galvo, its a grbl so I don’t think I have these settings
thank you!!
