Don’t like this “MULIT BS”…How do I get regular line -speed/power displayed??
I am a little bit hot…
Any help is appreciated… Thanks
Multi indicates that there is more than one sub-layer defined for that Layer. If you want that to show something else, double-click on the layer, then remove any of the sub-layers you do not need until you have a single one remaining.
Thanks a TON. This LB is great, but, still learning all the tricks… Just noticed the “minus sign” by the layer name and deleted all not needed. Now I’m good to go. Appreciate the quick reply… Hank
