I’ve been trying to create a rounded corner 70 x 40 mm blank for cutting in 2mm plywood to make name badges. I created an .svg file from a JPG, but my jpg to svg converter doesn’t give a clean, single line all the way around. I’m trying to find a way to correct this but not having a lot of luck. Could use some help, thanks.
Did you try the offset
and select outward and outer shapes only…?
If you can post the svg, it might help us help you…
Try this
70mm_x_40mm_x_6mm_rad.lbrn (4.7 KB)
Thank you! That is exactly what I needed.
Thanks Jack, that was what I needed to know. Got it fixed now.
