How to Increase Maximum Cutting Width on My Laser Machine?
Hello everyone,
I have a question about my laser machine. Currently, the maximum cutting width is 100 cm, but I’d like to increase it to 102 cm. The technical support team sent me a photo showing where to make this adjustment, but I’m not sure exactly where or how to do it.
Could anyone explain the process to me? Is it possible to make this change directly on the machine, or do I need to use specific software? Any help would be greatly appreciated!
Thanks in advance for your advice.
5351B32D-BA93-4b10-9D3A-31A807EFF209
Does the machine have 2 cm more travel in the X axis?
On my OMTech 60 W laser, the machine homes to the right rear corner. The controller will not allow the laser head to move rightward beyond the home point, so the right end of travel is immovable.
Using the machine’s control buttons to jog the laser head left by 700 mm puts the X axis belt holder about 5 mm from the gantry brackets, but manually pushing it (with the power off!) beyond that point bends the belt in a way it does not like.
If your machine is similar, changing the software setting cannot increase the size of the axis, because the laser head will smash into the gantry at the left end of its travel.
I think I have 3 cm of margin. The honeycomb bed is 103 x 163 cm.
I’m not in front of the machine right now, but of course, I would check to make sure nothing is blocking.
However, when I move the axes manually, the size is exactly 160 x 100 cm. This all seems to be due to a software limitation.
Is that by shoving it with the power off or jogging with the arrow buttons on the machine display?
The size of the honeycomb is irrelevant and may not be centered under the machine limits. The X axis linear rail and whatever hardware hangs on it determine the extent of the travel.
If the laser head does, indeed, have another few centimeters of travel, then change the 700 to 702 in the Vendor Tools page and hit the Write button to update the controller.
Edit: That should be 720.
However, if the machine does not have as much travel as you tell the controller, the laser head will smash into whatever gets in its way and will probably damage something expensive and hard to replace.
Thank you for your reply.
I will check before making this change.
Can I do it in lightburn?
Sure: Edit → Machine Settings → Vendor Settings → X Axis → Max Travel, enter the new value, and hit Write to tell the controller.
You must also update the size of the LightBurn workspace to match: Edit → Device Settings → Working Size → Width.
Thanks for the tips and information, I’ll keep you posted. :grinning:
Hi, there,
I’ve found the time to test but the modifications don’t seem to apply in the machine.
The machine is well recognized, I can add it in lightburn.
What values did you try to apply?
Did you click the Write button to write them into the controller?
Upload a screenshot of the Edit → Machine Settings → Vendor Settings for both the X and Y axes showing the Max Travel fields.
Hey, after another try it works! I had the wrong axis :slight_smile: So I went up 2cm to be able to go up to 40 inches.
Thanks a lot for the help.
Verify that axis length is once again the original value, because two weeks from now you’ll wonder why it changed. :grin:
I’m still surprised the machine has that much space on the axis, so thanks for letting us know it works!
