How to made my logo into a vectored pdf file
Without an image of your logo, it is just going to be an educated guess. One must expect that your logo is of a bitmap type currently (is it?) and you desire a vector format. The easiest method is to import the image to LightBurn and use Trace Bitmap feature. This will result in a vector format file. There may be some editing required to have it match your image and your requirements. If there are multiple colors, it may be advantageous to apply each color to a separate layer.
LightBurn does not support PDF exports, but once you have completed the editing, you can export as an SVG or an AI format file, both of which can be converted to PDF format.
