How to make a mark when using the ruler
My plan width is 242mm and I need to put a mark at 121mm I just cnnot find the way to do it
Can you upload your Lightburn file?
BirdHouse
What I am trying to do is find the center of the roof panel parallel with the tbs, the slots are 8" apart on the outside edge of the slot I also need an over hang of at least 2".
I hope this works.If not go to boxes.py and scroll down to bird house/Feeder
See picture. And I uploaded the SVG
Roof
Looks like you uploaded an image or something other than your LightBurn file.
Yes that is what I am trying to do, also the file I uploaded is from the Boxes.py site and when I generate the file it comes in as a file but not Lightburn and that is another thing to learn well at least to send it by email
The type of file you can drag and drop on the supply window is limited… if it’s under 4mB, append a .txt and it should upload then…
If it’s a lbrn2 file is should upload as is.
If the file is larger, such as a video, put it in something google drive and post the link here…
