Help! How do I merge both PNG grayscale files together without one engraving through the other one. See photo below. The flag is cutting through the eagle.
You have to use the Cut Shapes Tool.
Grab your eagle shape and do a little outward offset (or draw a circle very little bigger than the size off the eagle) select image and offset and cut the shape.
Then you have a hole filled with the eagle.
thanks, I will give this a try.
