How to reestablish a Neje Max with extensions Homing after a Lightburn Update
Have a Neje Max 3 with extensions with a plot space of 840 to 1030. I remember when I first set up the machine would home half way and had to place negative numbers for it to take the full plot area that appeared in Lightburn.
I updated lightburn, but now I dont know where it homes or origin. The machine is not getting the plot area that appears in Lightburn. When I home it, it hits the rails and makes a horrible noise. Does someone know how to fix this.
I turn lightburn on and this appears in console.
[OPT:VMZHL,35,254]
Target buffer size found
ok
Homing
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Once the Home command ($H) is sent, it is all in the controller. Lightburn has nothing to do with it after that.
In the Console window, enter $$ to get the list of GRBL parameter settings. Then copy all the $xx parameters to a text file and save two copies each in different places. Never change any parameters without doing this first.
Use the Machine Settings window to check the parameter settings.
$3 controls Jog direction.
$23 controls Home direction.
$130 controls Xaxis max travel.
$131 controls Yaxis max travel.
Check and adjust them in the order listed.
I hit $$ and this is what came back
$0=10
$1=255
$2=0
$3=0
$4=0
$5=0
$6=0
$10=0
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=250.000
$25=2500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$40=0.500
$100=80.000
$101=80.000
$102=80.000
$110=15000.000
$111=7500.000
$112=7500.000
$120=1500.000
$121=750.000
$122=750.000
$130=810.000
$131=460.000
$132=100.000
ok
This thread should be ended because it is for the same machine in My laser losts its coordinates. I have a Neje Max with extensions. My laser is at 0,0 position but in Get position it shows X = -1432 Y = 484 - #83 by Amazinggiantflowers
@thelmuth is currently providing assistance there.
