How to run five diode laser machines with one computer
Hey guys… I am planning to have 5 diode laser machines. But I’m stuck with how to run them with a single windows computer… Can lightburn be run with multiple instances with usb port expander kind of thing with each instance attached to a virtual serial port and running different images in parallel.
If no what are my options… buying 5 different laptops will be too expensive task. I do not want to go away from lightburn as I have mastered it and am omfortable with its UI after working over 6 months…
But if its not an option then any other software recommendation is also fine.
i use 3 laser machines with same computer in 3 instances of LB and have no issue
SO you open lightburn three times and for each instance select a different com port and it works ?
Three machines run different images and settings ? :thinking:
yes i exactly act like this
