Looking for a video to run two lasers off of one computer
You don’t need a video. Install both lasers into Lightburn. Make sure they are each on their own connection, differnet COM ports, Ethernet, whatever. Don’t try to run them both through the same USB hub. Switch between lasers as needed.
If you want to run them both at the same time, make sure they work individually then open a new Lightburn window. (File Menu> New Window) Select one laser in one window and the other laser in the other window and away you go.
