I have this panel I’m going to cut out, but I’ve decided the OD of this piece i’m going to rip down to exact size. How can I select within light burn to ONLY cut on the interior of the tabs? Basically only wanting the laser the cut out the U part. See Attached Photo.
Select everything, make editable (nodes), put the mouse over the left top corner and press “b”, (break apart), do the same with the right top corner. Now you have separated your shape, mark everything except the top line and send it to your laser for cutting.
You can also group your selection, this is often more practical.
Thank you! Can’t wait to try this out. Appreciate your time.
