How to separate layers of the same colour
So i’ve got a text and a QR code that are both black, but the issue is that when i try to fill in the QR code ONLY, since they are the same layer it applies also to the text. Is it possible to separate layers of the same colour?
Most likely an easy fix, but without seeing what you are talking about we are unable to tell.
Post a screenshot at least, and even better post your lightburn save file for use to look at.
You cant separate layers of the same colour (they are the same) however you can assign other layer to e.g. the QR code so that you can set different Cut/Layers settings for each one e.g. QR (C00) set to Fill and text (C01) set to Line.
