Within lightburn there is displayed grid with the zero reference at the top left 0:0. how can i move this point of reference to the center of the grid. So that the numbering horizontally is postive to the right and negative to the left, same with vertical postive to the top and negative to the bottom. The end goal is to be able to adjust things off the center lines verse the left and top. Example I have two images I want to equally space on either side of center, if one is 20mm on the right of the line the other would be -20mm on the left when looking at the Xpos values…
Lightburn is laid out like your work area, as far as I know there is no way to call the center 0, 0 as that is the home position of the machine…
Might want to explore some of the alignment tools that Lightburn has, you will be pleasantly surprised about how effective they are. They might do what you want in a single click…
This video uses lines, but it should work with any object…
It’s always nice to have a file where we can examine what you are doing and assist you with learning Lightburn…
Good luck…
