How to set up alignment guides?
Is there an easy way to set up an alignment guide layer that will appear when framing, but not be printed out?
For example, I have wooden plaques that vary by just a little on height and width. The design I have in lightburn needs to be centered on these plaques. While I have physical guides on my machine, I need to move them a hair or two manually to get them perfect.
I’d like to have some corner guides that make visualizing this easier. I’m aware I can turn the output/show on/off, but is there a way to modify that layer so that they show when framing, but are not engraved?
Hi, just use a tool layer T1 or T2.
You could make a grid array and either use T1/T2 for that or one of the other layers and turn off the output for this specific layer.
Ah perfect. Didn’t know that feature existed.
Reference video for those asking a similar question: https://www.youtube.com/watch?v=1QAOBuHK8X0&ab_channel=ThatMomwithaLaser
Make a single outline box on a separate cut/layer. Turn on for framing and turn off when ready to burn
