I can’t find where to set 24"x24" material. I do not have device connected at this point.
While you do not need to be connected to a laser system to run LightBurn, you must create a ‘Device Profile’ to have LightBurn work properly. This is where you will define the workspace size.
If you do not want to connect to a laser, you can set up LightBurn using the Manual process described here: https://lightburnsoftware.github.io/NewDocs/CreateManually.html
Got it thanks. It’s a little odd that these settings are hardware coupled.
The page size is intended to specify the working area of the machine so LightBurn can prevent you from running out of bounds.
If you have CNC experience you likely have expectations about how things should work. The way LightBurn works is different than CNC software, but very similar to most dedicated laser software.
