Hello finally got my laser to work. I’m working out the kinks but I did a test run before this and was fine. I did this one and it did a double print anyone know why or can help me so this does not happen. Did not look like the wood moved so I’m not sure
If you’re engraving in one direction this appears to be excessive Overscan.
Open the Cuts / Layers window. Your image should be on an Image layer.
Double click the name of the Layer and the Cut Settings Editor window will pop up.
Please confirm that Bidirectional scanning is off,
Turn off Overscan (just below that).
I’m curious about some of the other settings in your Cut Settings window for the image layer.
Please use Snip or a screen capture tool to grab it and drag it into a reply here.
