How to tell my CNC machine (FoxAlien) the size of my project piece and the design on my project piece
Hi there,
I am not sure how to set up my machine so it knows how big (the size) my project piece is AND how big (the size) of the design I want to laser on my project piece.
I believe the max space on my machine is X is 380.00 mm and Y is 380.00 mm (Not sure what the proper term for that is).
The size is whatever you make it. You size it to what ever the piece you are going to apply it too.
Im sorry, I didnt follow that. So if I have a piece thats X 344.4 and Y 238.1. but I want to put a small design in the middle, how do I tell the machine the 344.4 and the 238.1.
The machine work area (my term for it) is a fixed space. That is also the grid area displayed by Lightburn.
I represent the material size and shape with a Tool layer. For example, if I am working with 12”x12” Baltic plywood, I create a 12x12 inch box, which I park in the front left corner (I always use Absolute Coords).
Any design work I do stays within that box. If I have multiple parts with an odd shape, I just draw a rough version of that shape to use as a guideline.
For assemblies with more parts than will fit in the Tool layer outline, I just move stuff in and out as needed.
Tablet is driving me nuts! To center the design in a larger part:
  1. Jog the laser to the desired location (I made a 1” disc with a tiny hole and crosshairs that I place on the material) with Fire active.
  2. Notice there is a small red cross on the screen. I just drag the entire drawing until it is centered over the red cross.
  3. Remove the locator disc if you used it and turn off the Fire button.
  4. Fidgit with the drawing position a little using the Frame tool, (sometimes I move the material) and you should be ready to cut or burn.
I Use this method a lot when trying to make use of scrap pieces.
Like @MikeyH said you would make a 344.4 x 238.1 rectangle and work your project within that rectangle. The grid on which you are working should be the work area of your machine, which you put in when you set up your machine.
In your case 380mm x 380mm
Thank you both so much for explaining that to me. Makes sense now! :folded_hands:
Hooray! Sounds like you are back in the game now. :grin:
Yes lasered a design last night. I just eye balled it and used the framing button but later this week I’ll try a design using the method you both described
