Hi all,
I just got a two trees TS2 and I’m having a fight with the auto focus.
If I use the settings provided it is not focuses correctly.
I’m just trying to cut some 3mm plywood and keep getting a flame alarm, and really shallow burned area rather then a cut.
I did the focus test and at 6.7 it gives me a beautiful fine line that lets light trough (cutting al the way through) at 300mm/m and max 80% power
How do I translate this to the programmed macro’s
It came with the following macro’s:
Engraving:
$HZ
G91
G1 Z0
3mm cut:
$HZ
G91
G1 Z-1.5 F300
I know absolutely nothing about coding but my idea of logic thinking made me think that if I would put in
$HZ
G91
G1 Z6.7 F300
It would set the z axis to 6.7 and make the same line as the focus test. It does not.
my next step was to set it to the engraving
$HZ
G91
G1 Z0
and check in the move tap. What value light burn gave for the z axis. is was 2
So I changed my Cut 3mm to:
$HZ
G91
G1 Z4.7 F300
and checked in the move tap. I now stated z as 6.7
But this also did not create the same effect as the focus test. It just give me shallow burns that set of the flame alert and not cut through the material.
Clearly my laser can make those lines. But I can’t seem to get it set up to do so. Can anyone help me with setting this up?
