how to turn on the light beam to check the contour before cutting, engraving. Version 1.3.01
I’ll interpret this to mean that you want to use the laser light for framing operations. If that’s not the case then please correct me.
  1. Go to Edit->Device Settings
  2. Enable “Enable laser fire button”
  3. Enable “Laser on when framing”
  4. In Move window set Fire Power % to a very low value. Then push Fire. Change Power level until you can see the laser light appropriately. Make sure you have your goggles on when doing this. Push Fire again to disable.
  5. Test Framing operation. Laser should fire when framing.
