Since the 2.0 update, my screen display is HUGE. I’ve adjusted the text size, but what I have now is only half of the screen showing my workspace and the other half is the cuts/layers portion. Also, the cuts/layers, laser, move, file list… is on separate tabs instead of being able to view them the way I was before. The tool layers are also under the other layer options instead of being on the same row. I’m trying to edit my offset/fill layer, but the screen is so big that I can’t access the button that says “ok”. This is affecting my work flow significantly. I downloaded the next update that said there was a fix to this, but so far everything is still looking the same.
