Hy-t60-hx $30 setting
Any tips you may have to figgure out the setting $30 should be for this Co2 Laser Powersupply? HY-T60 CO2 Power Supply - tekorycnc
Or do these two values just need to match? so the software can scall 0-100%
Exactly. The value itself doesn’t matter. Though it doesn’t make sense to set it higher than 1,000 or 10,000. You don’t need more precision than a tenth or hundredth of a percent.
I suspected that was what would happen (*Percision scale) with larger numbers. The 20000 pictured was a holdover from my CNC router that I had bolted a 5-watt Diode Laser to. (0-20000 rpm)
