I’m running a D1 Pro 20w laser with frame extensions. I’m using Absolute Coordinates
Lightburn recognizes my laser
I can home the laser using the software x0 y0
I can frame my design
I can burn my design.
I’ve attempted restarting the machine and the software. I’ve switched usb ports on my pc and restarted everything, careful to always connect the xtool first then open the software application.
No matter what, I can’t use the jogging functions or specify the coordinates and hit the ‘Go’ button.
Spent time over Xmas adjusting gantry which was slightly out of alignment. Didn’t get around to using D1 till after Xmas.
Decided to test print 'n cut…
Manually homed gantry;
Began process to jog to reference mark;
Initial ‘right’ move went desired distance horizontally (25mm);
Further ‘right’ jogs inoperative;
Tried ‘down’ jog - moved DIAGONALLY left and down;
No further movements except ‘right’ selection moves right and ul! Then permits ONLY a repetition of this pattern.
Question. Has there been a Win 10 update in this time frame?
Sorry for my delayed response. I tried what you recommended. Commands that I manually enter in on the Console screen are accepted and the machine moves but any of the movement I make on the Move tab does nothing with the laser.
