I did connect it properly, I expected that it will work smoothly, to happen, but instead I got few errors like alarm 9 which I used a console to fix that and I disable homing and I manually set the origin, I turn on enable rotary. Then I rec another error “Alarm 3 error” then the roller i thinks rotate 360, which I dont want to. Is there a video I can watch or so. Thank you in advance!
Hello and welcome to the forum!
Alarm 9 means that your machine tried to home itself but couldn’t.
You did the correct thing by disabling auto home on startup in your device settings.
Alarm 3 means that your laser has lost its USB connection to your computer.
Here’s our rotary roller documentation for your reference.
In most cases, Current Position is the best Start From mode to use when working with a rotary.
This helpful page includes a video that may be useful to you.
Let us know if this helps or if you have additional questions!
Thank you, I will watch the video and follow instruction and will update here. Thanks again
Here is some extra guidance that also covers some Sculpfun aspects:
