I can't connect my xTool D1 Pro to Lightburn on my MacBook Pro
I have a MacBook Pro 2020 version without an integrated USB port. When I use a USB dongle + the cable and connect my new xTool D1 Pro to my MacBook, I can’t find the laser in Lightburn. When I use the xTool Creative Space software, I have no troubles to connect the Laser with the computer and the software. It’s only a problem with Lightburn. I have imported the configuration file (xTool-D1ProV3.lbdev). How do I connect my xTool to Lightburn?
Make sure you turn on the Xtool D1 Pro first, then start LightBurn. In the lower right side of the screen you should see the Laser window. Next to the Devices button should be a dropdown menu, for me, there are two options to choose from, cu.usbserial-1410 and cu.URT0. It works if I select cu.usbserial-1410, but not if I select cu.URT0. Sometimes I forget to start things in the right order and this gets switched. Hope that helps.
