I can't get print and cut working with trocen awc7813 board
I’m new in this world, so I saw a video where explains how to use print and cut. I followed the steps but when I try to cut I get a this message.
“Out of limit”.
I place my red spot in the center of each mark and i follow the steps but it doesn’t work.
Is this feature not working with trocen?
Perhaps the overscan region on either side of the engraved area (I assume the project involves engraving) extends beyond the machine limits after applying the P-n-C alignment.
You must set up each part of the project so it fits within the machine limits, which often requires dividing it into separate chunks within the alignment targets. Each of those chunks will have overscan regions on both sides, so using the Preview helps identify and fix problems.
Uploading the offending lbrn2 file and some pictures of the material on the machine platform will help us look over your shoulder.
Using preview is great, ensure you enable show transversal moves which shows the head movement (red) when it’s not lasing.
