I can't get the nodes on my project, wanting to weld everything together
I’m trying to make an ornament for a friend and usually I can get the nodes but for some reason it’s not working. I have ungrouped, clicked on the areas to weld and when it didn’t work tried to use nodes to break the lines I didn’t want.But again no nodes. Is there a trick or something I’m missing?
Also I don’t know how to take a pic on Lightburn to add to the post.
How is this art built, meaning it is vector art of an image/picture made as a raster? If you used LightBurn to draw the shapes that make up your art, you may need to convert these shapes to paths first. Node editing is for vector art only.
Post your LBRN2 file for review, if willing. :slight_smile:
I tried to convert to path but it wouldn’t let me, it was light grey which is unfunctional, but I could do covert to bitmap, should I try that first?
That worked to take pics with my phone! Thanks
Finally got the bit map to work, I needed to highlight the whole ornament and it worked! Thanks!
