I’m trying the trail version of loghtburn, I can’t engrave, the laser tracks correctly the project but does not emit the laser beam. Am I the one making a mistake or is the trail version limited and doesn’t allow you to hack? Thank you.
Helo Emanuele,
LightBurn trial is complete, all features work.
Can you share with us your EDIT > settings and EDIT > device settings screenshots
Also what speed/Power are you using?
Speed 6000, Power 10% , does not emit the laser light bean.
Hi Emanuele,
10% power 6000mm/min speed on a diode laser, i think the laser does trigger you just cant see it
What laser do you have?
Try the test below on cardboard
Dot Test with Angle.lbrn (46.3 KB)
AtomStack S20 Pro
How do you set it up to avoid the problem in the center created by too many close passes of the laser?
