Hi, I am trying to select a part of text and I can’t do it by dragging the mouse to delete what I don’t need without having to delete everything, is there any way I can make it possible to select the part of text that contains error and delete it? for now I have to be removing letter by letter, I hope your help and thank you!
If the text is still “editable” within LightBurn, no, you can not “select text” to delete or change, not at this time.
Thanks for the reply
Text exists in two states in LB - as editable text, or as vector path shapes. Once you have chosen to covert text to path, you can only edit it with a node editor.
Thank you, I wanted to do it in editable mode, but now I know that it is not possible yet, I appreciate your answer.
You can’t select the text, but you can double-click it to place the cursor, then edit with the cursor keys, delete, and typing. We just don’t have the ability to select blocks of text yet.
which would be a nice option
While this suggestion has been around since December 15, 2018, it has only garnered a modest level of support.
https://lightburn.fider.io/posts/468/text-selection-editing-on-page
