I cleaned the Laser Module because of Dust
As title says I striped the module and brushed it gently of all it’s parts (3)…
And when it was back together all was great…
Coffee time…Come back and turn it on and all hell broke lose, the laser hit the side rail and vibrated til I turned all off…
I go to frame a job and it say’s Busy, green line light on until I switch off and pull the USB and power plugs…
Then there was the time the Busy light never went off until I switch Lightburn off…
I am attempting to post some screen shots of the console, hoping it will help ???
I have/had limit switches installed but without doing the Firmware (cause I really can’t get my head around it)…
All was going good with Homing every time I turned on the Laser…
I tried unplugging the limit switches but no…
Hoping someone can help…
Sorry Mike I though this wood happen I could only post 5 files per thread…
Forget post 2 and 3 …
Can you see anything wrong in the settings…
I personally think it’s the homing…
I spied a mistake in one line when setting the Macro…
Fixed that and now I get error 5 Homing cycle is not enabled in your Grbl settings…
