when I use my lightburn, i only use it for fill, offset fill and line. Now i have customers that want the image to cut. But when i look at the drop down menu, I dont see cut. i checked to see if the software was up to date which it is. Am I missing something?
There is no ‘Cut’ setting you would use ‘Line’ and adjust the power, speed and the number of passes (higher power, lower speed etc.) accordingly to be able to cleanly cut through.
Each material will be different though, so you may find the ‘material test’ useful, this can be found under the ‘laser tools’ dropdown
You use ‘Line’ for cutting. It’s the power, speed and number of passes which determine whether it just marks the material or whether it cuts through
