Hi. I’m new to Lightburn but getting there with 2 successful engravings so far.
My current issue is the preview time is way off compared with the real world engraving… I realise I need to adjust the settings in ‘Device Settings’ and then ‘Additional Settings’ and I can adjust the simulation parameters but I don’t understand which setting relates to which setting of my set up.
Can anyone provide an idiots guide as to where in Lightburn I can get the necessary settings from for the simulator.
If you type $$ in the console and press enter, you’ll see a bunch of numbers output:
$110 and $111 are your maximum speed in mm/minute. Divide by 60 to get mm/sec.
$120 and $121 are your acceleration for X & Y in mm/sec^2
The $110 and $111 values are also your rapid speed, so you should be able to plug those numbers into max speed and rapid speed, and plug the $120 & $121 numbers into both the cut and engrave acceleration numbers, and then just leave the others as is.
