Light burn recognize my two tree laser and its not on the list please help
What do you mean? LB found your TwoTree laser but is not on which list?
I tried to add my two tree using light burn. I went down the list to add it manually I did not see it. It comes with a memory card. Do I need the card to make it work
LB don’t recognize the board, if is a GRBL you have only to select this and set the correct work space
Which model Two-Trees Laser do you have?
They were kind a produced a video with all the set up info.
If you don’t have the TT-55 S you’ll need to find the right video.
