I`m trying to engrave text with Fill mode and have an issue. Its look like destortion.
As you can see versions 1,2,3 have this problem.
Version 4,5 have Offset fill and looks fine.
Version 6 just Line mode.
I tried different speed settings from 100mm/s to 1000mm/s. Same issue
Adding to above timing can reset to defaults after upgrading, need to redo timing.jump.delay or reload the backup config file. Timing issues really show up on text, crosshatch, bi directional settings.
Guys please help. Same thing. Don`t know how to solve this problem.
On image aluminum black card. 1 pass.
Cant engrave properly. Even in image mode.
Looks like laser beam should turn on earlier, later.
This settings I found when I install machine from USB
Also I ask Monport support for manual and they send instruction which has slightly different settings.
Seems like these parameters are not strict and maybe I should can “play” with them to customize them specifically for my laser.
THank you for video and massages. Will keep you updated
I recommend increasing your “Min Jump delay” to 200us.
This value dictates how long the galvo mirrors should wait to settle after a jump before they move again.
The value of 20us seems a bit low. The only drawback of a longer setting here is a longer job time.
Try another engraving with the values of the screenshot from Monport with “Bi-directional fill” turned off and send us a picture please.
This doesn’t look too bad if you ask me. Although, I’m not sure, what happened on the last T.
If you change your layer settings to “Fill shapes individually” instead of “All Shapes at once” it makes it easier to visualize the start and end of each path.
It’s hard to tell from the picture if the left side is just blurred from the picture or overburning. You can try to emphasize the effects by increasing the power setting.
If you do get an overburn at the start of a mark, increase the “Laser On TC”
The right sides of every character do show signs of an overburn at the end of each mark. This can be an indication of a too high value for the “Laser off TC”.
Review this page for explanations for the Delay Defaults.
Obviously, the settings they provided are not accurate.
At this point, I’m curious how the Monport-provided program would perform. Can you test this?
Thank you for your response. I did photo with room light. Thats why its hard to see. But the problem still exist. I will do better photo tommorrow and will do some more test.
Monport provide me no name soft. It is called BslAppSimple. It`s even not EZCAD. I was shocked when I resived an answer. From support "due to the high rate of EZCAD motherboard connection
problems, we have replaced the EZCAD motherboard with a BSL motherboard. You can now use the BSL software for processing, which has the same interface as EZCAD.
I defenetly would do some test there. But …god this is soft from early 90-s. Interface like windows 95. ha-ha
No success for now.
Text( or image) shifted (extended) to right side(bi-derctional off)
I atached image from preview window in lightburn which show laser beam path. And we can see that have happened in this area. So laser beam back and we have right thickness. And this gap on T its “no need thikness”.
will try their soft now and look video you mention
