Hi,i need help about calibration axes,because i dont have right angle of 90°
Recent topic that may be helpful…
Check to see if the machine is square (has 90 degree corners) then check to see if the gantry is at 90 degrees to the frame of the machine.
If the gantry has a belt on each side, it is easy to be off 1/2, or even 1 tooth from each side.
