I have both an xtool and a Ortur Master 2 S2
Can i switch between both my machines with lightburn Shadow?
Could you explain further what is Lightburn shadow?
You can have many devices in your Lightburn program one per instance.
If you use separate USB ports on the PC, you can run 2 instances of Lightburn independently, one for each machine. You cannot have both machine USB cables into a splitter fed from one PC port.
