I have had a new machine and laser need some help setting it up ortur master 2 pr s2
hi all
so had a new machine its a ortur master 2 pr s2 with 10w laser
i have the extension bed so now its 400x800 but how do i set the soft limits as it has only got limit switches in then homing position
also does lightburn automatically know what laser i am using do i need to install drivers etc
There are a number of previous posts on this. Here’s one:
Windows 10 should ship with the drivers necessary for communicating with that laser. You should see a COM port assigned to the laser in Device Manager. If not, then a driver may need to be installed.
However, you still need to create a new device for your laser in LightBurn. Push the Devices button in Laser window and try “Find My Laser”. If that doesn’t work you can create the device manually.
