I have no visual icons for the tool path
I have the S9 laser. I can not see my tool path color icons. I minimized and maximized my screen. Still no visual tool path icons.
Have you tried ‘window’ dropdown menu then ‘Reset to default layout’ ? that has worked for me in the past
If David’s suggestion does not work consider this…
LightBurn’s default layout requires a minimum vertical resolution. If your display has 768 lines of vertical resolution or less then it’s likely insufficient to display the Cut Palette.
In that case, collapse the two panes on the right side of the screen to a single pane and you should be able to reclaim some vertical space, sufficient to show the Cut Palette.
That did it. Restored from the window drop down list. Now I will have to figure out if I have the trial version of lightburn. I uninstalled then install. I think I should have done the license install. O things I get myself wrap around the axcel. Thanks for the tip
They are the same version, you need to put in your key. “Help → License Management”
