I hit home and it goes to the front right corner. INSTEAD of the designated Front left. Left is Right?
Ive tryed looking this up but nothing i find or try works. If i hit the move left arrow it goes right. Amd vise versa. If i hit home it goes to front right corner. The start is selected to be front left.
Sculptfun S30 Pro.
Is it possible that you are just looking at the laser from the back? Meaning the laser is intended to be rotated180 degrees?
Is your machine oriented this way where the bottom of the image matches the bottom of your laser? If not, then it’s upside down.
Just trying to get it setup inside. Not using it here.
This is how i have it setup
And the up and down arrows work respectively.
Can you make absolutely sure that you have all your cables plugged in the correct way. Meaning that they aren’t reversed.
I’m surprised Sculpfun would ship out a laser configured incorrectly. I’ve seen it for when extensions are added but I wouldn’t expect it for a complete unit.
When you say that the machine attempts to home top-right does it then crash into the railing?
If you’re confident the cable connections are correct can you run these commands in Console and return output:
$I
It runs into the rail and makes a racket.
$0=10
$1=25
$2=0
$3=4
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=7
$24=200.000
$25=3000.000
$26=250.000
$27=2.000
$30=1000.000
$31=0.000
$32=1
$100=80.000
$101=80.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=410.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
$I
[VER:1.1h.20220925:]
[OPT:V,15,128]
Target buffer size found
ok
Run this in Console:
$3=5
After that, test jogging controls. They should work correctly. If not, report back on how they behave.
Assuming those work correctly, try homing but be prepared to stop the machine. I suspect it will attempt to go top-left but want to confirm.
Fixed it perfectly
