I installed Lightburn for my Sculpfun C1. The laser moves, but it is extremely low even if I put the power on 100%. Any idea how to increase the power output? Probably just a simple setting that I cant find
You should follow the setup details in the Lightburn grbl setup.
It likely that one of the machines are set for an S-Value max of 255 and the other 1000.. Both Lightburn and the machine ($30) need to know how the range is used.
What are you comparing it to? What are you trying to do?
It is a 3w laser and basically suitable for engraving only.
By the way, I am waiting for Sculpfun to put the S9 5w module with the 0.02 dot on the new C1.
