I just replaced the NEJE 30 watt diode module with a new one. Now it will not cut?
It seems like it does not fire up with any power to cut ? It is in focus and the power is at 40% enough to cut what I need to cut as with the old module when it was new.
Share with us what you have and how you are supplying power to the laser module.
Which NEJE machine you have, a link is nice and what was the old and new modules?
You description is a bit difficult … is it just a diode module or a diode machine?
Q) Share with us what you have and how you are supplying power to the laser module.
A) Diode laser cutter field size of about 10" X 14" it uses a 12 volt power supply that will plug into a wall outlet.
Q) Which NEJE machine you have, a link is nice and what was the old and new modules?
A) NEJE Master 2?2S Plus and the replacement module was exactly the same as the old one.
Q) You description is a bit difficult … is it just a diode module or a diode machine?
A) The machine is a diode laser cutter.
I have had the machine for a few years and replaced a module before and did not have this issue happen. This is the third module. I do not use it very much and probable cut once a year for what I need.
What am I missing here ?
Thank you for your help.
Regards,
Randy
