I keep getting an Alarm 11 error when trying to start a project. The machine will home, frame, but nit start without Alarm 11. Please explain as I am new to laser engraving.
“error:11” : _(“Max characters per line exceeded. Line was not processed and executed.”),
Most likely cause is you have Enable GCode Clustering enabled in the Device Settings window.
Second is that is a communications issue due to a bad USB cable or connection.
Thank you for your response. I will try this.
