You do not provide any context. What did you want to achieve? The process looks more difficult than it has to be, but I’m not sure what your goal is. Add your laser model and type explicitly, for example, setting the origin to top-left is incorrect for most diode lasers and such the guide does not apply.
Oops I forgot, It’s about a way to use the Xtool P2 co2 Lasers camera I knew there had to be a way to be able to use the Camera with lightburn, I’ve seen some complain that they can’t position there work very easy, this way is very fast for me
PS Thid is all new to me
Starting with an easy shape is a great idea to familiarize yourself with the process. I run both programs at the same time, it works for me
AS for the Home 9 dots Mine was on the center dot, so I moved to the upper right
Establish the Home Position: Set the home position in LightBurn at the top left of the 9 dots, similar to Creative Space.
