I lost the color bar on the bottom after last update on reset to default
My layout when I return to default setting doesn’t include the color stripe at the bottom. Holding shift on Lightburn start up didn’t help
You can try putting the LightBurn window in full screen mode and then reset to default.
I hade the same problem
In LIghtburn go to Window file make sure color palette is checked.
Thank you- I set lightburn to full screen and it all came back.
Bob G
Please mark the problem as solved so that others will find this solution faster.
